  • 12.96K
  • 991
  • 2.98K
Message 11 of 14
Re: Broadband connection
the 16qam could be noise on the upstream - the levels at 43 are fine - variations in the upstream can cause a reboot but they have to rise to 50+ for that to happen - but i think if that happens you would see T3's and T4's which are not there - do they show in the network log as a reboot clears the other figures - not sure if it also clears the log
you need more input from VM - will flag the thread and hopefully get someone back next week
@ModTeam- this has been looked at and nothing seen but theres obviously something as the connection is dropping most days
____________________
Tony
  • 57
mayburyds
Message 12 of 14
Ok, Many thanks.
  • 11.7K
  • 347
  • 678
Forum Team (Retired) Samantha_L
Message 13 of 14
Hi mayburyds,
Thanks for posting on the community.
Sorry to read you are experiencing intermittent broadband connection. I can see you have had advice from the community which is great.
When I checked your line, there is an SNR (signal to noise ratio) fault in your area which is causing intermittent connection. The reference number is F006615746 and has a review date of 15th October. As this is a review date it can be subject to change.
For any updates by all means post back here.
Sam
  • 57
mayburyds
Message 14 of 14
Ok, thanks for letting me know.
Cheers.
