on 08-05-2021 20:40
Hi all,
The past few weeks I've been experiencing loss of speed. My internet speed is supposed to be 200mb but after a few speed checks its dropped to 70 - 90mb.
Also I've started experiecing loss of internet for a few seconds on my desktop gaming pc (wired to router) it kicks out every 2-3 minutes for around 3 seconds but its enough to kick me out of games then it'll reconnect to the internet. Also does the same on my xbox to.
I've been with Virgin for years and always had good service I've done all the basics, checked the wires are tight, I've done the diagnostics etc.
on 08-05-2021 20:44
Post the network, upstream and downstream logs from the hubs admin pages back here as text
on 08-05-2021 22:48
08/05/2021 19:10:26 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/05/2021 19:07:18 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/05/2021 19:46:34 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/05/2021 06:42:27 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/05/2021 07:22:18 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
30/04/2021 06:42:25 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
29/04/2021 23:55:7 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
27/04/2021 13:05:37 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/04/2021 16:42:16 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/04/2021 16:42:16 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/04/2021 16:39:17 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/04/2021 16:39:17 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/04/2021 15:53:34 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/04/2021 12:41:37 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/04/2021 15:39:17 | notice | NOTICE ATOM is restarted as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/04/2021 11:19:10 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/04/2021 04:11:19 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/04/2021 11:19:10 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 08-05-2021 22:49
1 | 203000000 | 5 | 38 | 256 qam | 9 |
2 | 139000000 | 5.4 | 38 | 256 qam | 1 |
3 | 147000000 | 5.8 | 38 | 256 qam | 2 |
4 | 155000000 | 6 | 40 | 256 qam | 3 |
5 | 163000000 | 5.6 | 40 | 256 qam | 4 |
6 | 171000000 | 5.5 | 40 | 256 qam | 5 |
7 | 179000000 | 5.4 | 38 | 256 qam | 6 |
8 | 187000000 | 5.4 | 38 | 256 qam | 7 |
9 | 195000000 | 5.3 | 40 | 256 qam | 8 |
10 | 211000000 | 5 | 38 | 256 qam | 10 |
11 | 219000000 | 4.8 | 40 | 256 qam | 11 |
12 | 227000000 | 4.5 | 38 | 256 qam | 12 |
13 | 235000000 | 4.3 | 38 | 256 qam | 13 |
14 | 243000000 | 4 | 38 | 256 qam | 14 |
15 | 251000000 | 3.7 | 40 | 256 qam | 15 |
16 | 259000000 | 4.1 | 38 | 256 qam | 16 |
17 | 267000000 | 4.5 | 40 | 256 qam | 17 |
18 | 275000000 | 4.4 | 40 | 256 qam | 18 |
19 | 283000000 | 4.5 | 40 | 256 qam | 19 |
20 | 291000000 | 4.5 | 38 | 256 qam | 20 |
21 | 299000000 | 5 | 38 | 256 qam | 21 |
22 | 307000000 | 5.4 | 40 | 256 qam | 22 |
23 | 315000000 | 5.1 | 38 | 256 qam | 23 |
24 | 323000000 | 5 | 38 | 256 qam | 24 |
1 | Locked | 38.9 | 5 | 0 |
2 | Locked | 38.9 | 5 | 0 |
3 | Locked | 38.6 | 6 | 0 |
4 | Locked | 40.3 | 5 | 0 |
5 | Locked | 39.8 | 4 | 0 |
6 | Locked | 40.3 | 5 | 0 |
7 | Locked | 38.9 | 5 | 0 |
8 | Locked | 38.9 | 6 | 0 |
9 | Locked | 40.3 | 5 | 0 |
10 | Locked | 38.9 | 4 | 0 |
11 | Locked | 40.3 | 4 | 0 |
12 | Locked | 38.9 | 5 | 0 |
13 | Locked | 38.9 | 4 | 0 |
14 | Locked | 38.9 | 6 | 0 |
15 | Locked | 40.3 | 0 | 0 |
16 | Locked | 38.9 | 6 | 0 |
17 | Locked | 40.3 | 4 | 0 |
18 | Locked | 40.3 | 4 | 0 |
19 | Locked | 40.3 | 4 | 0 |
20 | Locked | 38.9 | 6 | 0 |
21 | Locked | 38.9 | 6 | 0 |
22 | Locked | 40.3 | 6 | 0 |
23 | Locked | 38.9 | 5 | 0 |
24 | Locked | 38.6 | 5 | 0 |
on 08-05-2021 22:49
on 10-05-2021 20:55
Hi @Ashleh1988,
Welcome to our Community Forum! Thank you for your first post!
I'm sorry to hear that you're experiencing connection issues!
I have looked over your account and cannot see any issues with your power levels at the moment. Can you tell us if you've completed a Pin-Hole reset to see if this will help with your wired connections?
Please keep us updated on this.
on 16-05-2021 08:33
ill try this today and let you know how I get on
on 16-05-2021 17:25
How did you get on?
Kind regards,
on 30-05-2021 17:46
Hi guys,
I've done the pin hole reset test its still the same i'm supposed to be getting 200mb but at this time im struggling to get over 60mb. I've reset the router multiple times and its still happening I could do with an Engineer coming out
on 31-05-2021 08:50
Hi Ashleh1988,
Thanks for your reply,
I have checked your account, your power levels, and the latency within your area there is nothing that would suggest the slow speeds, are the speeds on a wired or wireless connection?
Are you able to post a live BQM graph you can do so here
Our systems do indicate your 5gz frequency is busy.
Zoie
