on 12-11-2021 12:04
Hi, the base light on my hub began flashing green last night and cannot get a wifi or Ethernet connection. I have checked all connections and appropriately connected, any advice on how to resolve this?
thanks
12-11-2021 12:40 - edited 12-11-2021 12:41
Check with Area faults on 0800 561 0061 or if you have a VM landline 150 as local issues are not always shown on the VM status page.
I take it you have also powered down the Hub for a few minutes and restarted?
on 12-11-2021 13:22
Hi Adduxi,
thanks for the info, I have restarted etc and also reset
thanks
on 12-11-2021 17:09
Sounds like it's a disconnect between you and the street cab? Either phone it in, or wait a day or two for a VMO2 Mod to pick this up.
In the meantime, you could check all the co-ax cable connections from the Hub to the outside omnibox to make sure they are all "finger" tight.
on 15-11-2021 10:01
Hi EHumph,
Thank you for your reply, I have checked your account and can see there are some issues with your power levels that require a tech. I can get this booked in for you and will pop you over a private message.
Zoie
