on 23-12-2021 12:41
Hello, the issue seems very specific, i was trying to explain one month ago to an advisor but just received an hub extender which didn’t help at all.
The issue im experiencing is that 5G (Which is supposed to be fast for my 5G capable devices) Is dropping connections from time to time. But 2G is working fine with no issues. My tv is connected to 5G and when im playing it just drops connection and ping goes skyrocket, sometimes even disconnects me from online lobby. All smartphones, laptops and iPads support 5g broadband antennas but experiencing same issue. Pages stops loading for like 5min on all devices, if switching to 2G band it loads instantly. There is limitation on speed how much 2G can give and for me if i pay for 350mb which only 5G can support, i want to use 5G band without issues and connection drops. I cant find the problem, i think it’s a faulty 5g chip or hub is faulty. I will list the conditions so may be you will have an understanding what could be an issue.
1) Hub 3 is not obstructed and have shelf with open space on all sides.
2) Hub connected to pc via ethernet which never had connection drops.
5)Hub bands has been split to 2G and 5G for smart home operations
4)2G band dont have any issues (we have a smart home and almost all devices connected to 2G band which is arround 20 devices. They don’t loose connection, as far as i can see so far. Its been 5 months now.
5) House walls or reach is not a problem here, i can be in the same room and 5g just looses connection but wifi symbol is still there connected. That’s what annoys the most. While 2G operating fine the 5G is just playing up. Loosing connection like that like 3-6 times a day which imagine can be very annoying paying for such a expensive service.
6) Loosing connection doesn’t happen only evenings, this is 24/7 issue with my working pattern i can notice it happens all the time
If it’s worth to contact Virgin media for an broadband upgrade or replacement let me know, pr this is an software issue that can be resolved in some other way please let me know.
on 23-12-2021 13:50
Have you used a Wifi scanner to check for congestion on the 5Ghz channel and then choosing manually a less congested one?
Its worth noting that Wifi speeds and connectivity and not covered under your contract terms and are therefore not what you pay for.
on 23-12-2021 14:05
Firstly, avoid using the term '5G' which is a term for 5th generation mobile/cellular - you seem to be talking about WiFi on the 5GHz frequency band, which is a different thing.
on 27-12-2021 12:45
Hi sidomix,
Thanks for your post and welcome to the forums. It's really great having you on board with us in the Community.
I'm sorry to hear you are having an issue with devices connected on the 5Ghz network.
When the networks are split, it can be worth reconsidering which devices you connect to which band. Any devices closer to the Hub would be better placed on the 5Ghz band. Any devices further away from the Hub would be better places on the 2.4Ghz band. The speed can vary on WiFi and you may not get the full speeds. These are only guaranteed through an ethernet cable connection.
Taking a look at the account, I can see you've spoken to the team and they have already arranged for an engineer to visit.
Please let us know how this visit goes.
