cathymathieson
Broadband WiFi issues
We’ve been having serious issues with our WiFi over the last couple of months ... Holywood Co Down.  Engineers Been out twice.  Restart and it works for half an hour with limited availability ... anyone else having issues?
  • 2.42K
  • 131
  • 381
chenks
Problem sorter
Re: Broadband WiFi issues
you mean issues with your actual internet connection and not WIFI.
WIFI issues would mean that you connection was working fine via ethernet connection.
can you clarify what you actual issue is.
does it work fine when using ethernet?
  • 12.04K
  • 446
  • 1.07K
Hi you might need to think about using modem mode and getting your very own wireless router with 1Gb ports.
  • 2.42K
  • 131
  • 381
chenks
Problem sorter
usual stock response from you that does nothing to help the OP.
cathymathieson
Yes, my problems are the internet connection which impacts on our WiFi
  • 473
  • 22
  • 37
Sorry to hear you're experiencing WiFi issues Cathymathieson and that you're keen on getting it resolved.
When you spoke to us and when the engineers visited, what did they say and what did the engineers do?
Are you experiencing the same issues using a wired connection and across all devices?
Lisa
