on 28-10-2022 12:31
Hello,
For roughly the past 2 weeks or so, our broadband connection has been having some issues where every 5-10 minutes, there will be an incredible lag spike for a second or two, to the point where streams will buffer and games will disconnect temporarily or will fail to connect while searching for games.
It has become increasingly annoying to put up with and would like some help with the issue.
on 28-10-2022 15:27
I've done everything I can think of to try and fix the problem i.e. making sure all of the cables are plugged in properly, restarting the hub many multiple different times and even restoring the factory settings of the hub. Nothing helped unfortunately. It seems to be a universal issue, across both wifi and ethernet.
The only thing I can think of now is that its potentially an issue with the hub, although it is relatively new since we were sent out the latest one earlier this year/late last year, or an issue with the line to the house but perhaps there's some other explanation.
on 28-10-2022 16:07
on 28-10-2022 16:31
Thanks for the reply.
Here is all the info:
1 | 331000000 | 1.3 | 42 | QAM 256 | 25 |
2 | 139000000 | 3.4 | 41 | QAM 256 | 1 |
3 | 147000000 | 3.4 | 41 | QAM 256 | 2 |
4 | 155000000 | 3.3 | 41 | QAM 256 | 3 |
5 | 163000000 | 3.2 | 42 | QAM 256 | 4 |
6 | 171000000 | 3.1 | 42 | QAM 256 | 5 |
7 | 179000000 | 2.9 | 42 | QAM 256 | 6 |
8 | 187000000 | 2.8 | 41 | QAM 256 | 7 |
9 | 195000000 | 2.9 | 41 | QAM 256 | 8 |
10 | 203000000 | 2.6 | 41 | QAM 256 | 9 |
11 | 211000000 | 2.7 | 42 | QAM 256 | 10 |
12 | 219000000 | 2.7 | 42 | QAM 256 | 11 |
13 | 227000000 | 2.7 | 42 | QAM 256 | 12 |
14 | 235000000 | 2.5 | 42 | QAM 256 | 13 |
15 | 243000000 | 2.3 | 42 | QAM 256 | 14 |
16 | 251000000 | 2.1 | 42 | QAM 256 | 15 |
17 | 259000000 | 1.9 | 42 | QAM 256 | 16 |
18 | 267000000 | 2.1 | 42 | QAM 256 | 17 |
19 | 275000000 | 2.2 | 42 | QAM 256 | 18 |
20 | 283000000 | 2.3 | 42 | QAM 256 | 19 |
21 | 291000000 | 2.2 | 42 | QAM 256 | 20 |
22 | 299000000 | 2.2 | 42 | QAM 256 | 21 |
23 | 307000000 | 2 | 42 | QAM 256 | 22 |
24 | 315000000 | 1.8 | 42 | QAM 256 | 23 |
25 | 323000000 | 1.7 | 41 | QAM 256 | 24 |
26 | 339000000 | 1.4 | 40 | QAM 256 | 26 |
27 | 347000000 | 1.2 | 42 | QAM 256 | 27 |
28 | 355000000 | 1 | 42 | QAM 256 | 28 |
29 | 363000000 | 1 | 42 | QAM 256 | 29 |
30 | 371000000 | 1.1 | 42 | QAM 256 | 30 |
31 | 379000000 | 0.8 | 42 | QAM 256 | 31 |
1 | Locked | 42 | 33 | 0 |
2 | Locked | 41 | 5 | 0 |
3 | Locked | 41 | 2 | 0 |
4 | Locked | 41 | 5 | 0 |
5 | Locked | 42 | 1035 | 1008 |
6 | Locked | 42 | 3 | 0 |
7 | Locked | 42 | 2 | 0 |
8 | Locked | 41 | 1 | 0 |
9 | Locked | 41 | 6 | 0 |
10 | Locked | 41 | 2 | 0 |
11 | Locked | 42 | 4 | 0 |
12 | Locked | 42 | 3 | 0 |
13 | Locked | 42 | 5 | 0 |
14 | Locked | 42 | 18 | 0 |
15 | Locked | 42 | 4 | 0 |
16 | Locked | 42 | 4 | 0 |
17 | Locked | 42 | 5 | 0 |
18 | Locked | 42 | 10 | 0 |
19 | Locked | 42 | 10 | 0 |
20 | Locked | 42 | 15 | 0 |
21 | Locked | 42 | 12 | 0 |
22 | Locked | 42 | 15 | 0 |
23 | Locked | 42 | 23 | 0 |
24 | Locked | 42 | 30 | 0 |
25 | Locked | 41 | 21 | 0 |
26 | Locked | 40 | 40 | 0 |
27 | Locked | 42 | 44 | 0 |
28 | Locked | 42 | 52 | 0 |
29 | Locked | 42 | 49 | 0 |
30 | Locked | 42 | 61 | 0 |
31 | Locked | 42 | 60 | 0 |
0 | 49600000 | 41.8 | 5120 | QAM 64 | 1 |
1 | 43100000 | 41 | 5120 | QAM 64 | 2 |
2 | 36600000 | 40 | 5120 | QAM 64 | 3 |
3 | 30100000 | 39.5 | 5120 | QAM 64 | 4 |
4 | 23600000 | 38.8 | 5120 | QAM 64 | 5 |
0 | ATDMA | 0 | 0 | 0 | 0 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
on 28-10-2022 16:35
28-10-2022 10:25:55 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-10-2022 10:20:52 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-10-2022 09:50:38 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-10-2022 09:45:35 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-10-2022 09:45:26 | error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-10-2022 06:45:24 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-10-2022 06:40:21 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-10-2022 21:46:39 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-10-2022 20:42:50 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-10-2022 12:53:30 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-10-2022 12:48:27 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-10-2022 11:09:29 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-10-2022 11:04:25 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-10-2022 10:53:18 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-10-2022 10:48:15 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-10-2022 10:44:09 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-10-2022 10:39:06 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-10-2022 10:33:34 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-10-2022 10:28:31 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-10-2022 10:24:49 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-10-2022 10:19:46 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-10-2022 10:15:02 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-10-2022 10:09:59 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-10-2022 10:09:56 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-10-2022 10:04:53 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-10-2022 10:00:49 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-10-2022 09:55:46 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-10-2022 09:29:53 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-10-2022 09:24:50 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-10-2022 09:17:36 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-10-2022 09:12:33 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-10-2022 08:33:22 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
I recently set up another BQM just to make sure that it was still working fine, here is the live link:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/a4a4e9c7b58a32ee7202b717a00416284d...
on 28-10-2022 16:52
on 28-10-2022 17:16
I'll do that, thanks for the help! Hopefully it sorts everything out.
on 29-10-2022 12:31
Unfortunately, even though there are 0 Post RS errors, the issue does seem to be persisting. I could believe that it is simply interference (because our hub is really not in a good spot) but we've been with VM for 15 years now and the hub has always been in the same place. I don't remember having a problem so consistent as this before.
If anyone from VM does actually see this, I could do with someone coming out anyway, as the box on the outside of the house has been broken and the wire and connection (2 wires are connected) has been exposed for some time.
on 29-10-2022 12:37
on 29-10-2022 13:27
Modem mode seems perfectly fine. I realise it wasn't exactly a long period of time for testing, but I changed back to router mode and almost instantly the issue was back.
