on 16-07-2022 21:55
Broadband 75 Mbs when paying for 1.2Gbs?
on 16-07-2022 22:17
Hi @almark
What speeds does it show using https://samknows.com/realspeed/
on 16-07-2022 22:22
@almark wrote:Broadband 75 Mbs when paying for 1.2Gbs?
VM don't offer a 1.2Gbps service.
on 16-07-2022 22:23
Thank you koindly.
That sort of explains things, thanks. I always used fast, now I will use your link, thank you.
16-07-2022 22:25 - edited 16-07-2022 22:27
For Fast.com you must enable more parallel connections:
Personally I find https://proof.ovh.net/ to be the most consistent.
on 16-07-2022 22:26
The 1 gig service, I thought it was 1.2.
However...
Sometimes it can go really, fast.
on 16-07-2022 22:27
Hi again @almark
Check your network card settings are for 1Gig and not for 100MB
Also possibly try a different ethernet cable.
on 16-07-2022 22:27
Again, thank you, that is helpful.
on 17-07-2022 07:34
Personally I don't trust any speed test site and will always use this site.
Download 2 10gb files at the same time and you'll be able to see your max speed by simply adding the transfer rates from both of the download boxes.
on 17-07-2022 10:29
@sevsman wrote:Personally I don't trust any speed test site and will always use this site.
I only get 20MB/s on that site!
I use this site for accurate results:
