on 21-05-2022 20:59
Hi all, I’d like to ask for advice. I decided to move my Wi-Fi router to a different place but I’m facing issue that my broad band cable is not enough long and I need to buy longer one. Please can you suggest where I can buy 8-10m
thank you
on 21-05-2022 21:08
If, by "broadband cable", you mean the co-ax cable that connects your home-hub to the wallpoint, then this forms part of VM's network and uses specialist cable. You'll need to call VM and request a non-fault tech callout at a flat charge of £25
If, by "broadband cable", you mean Ethernet cable that connects your home-hub to a laptop or suchlike, then any reputable electronics retailer can provide these.
on 21-05-2022 21:10
Hi, yes that’s what I mean co-ax cable. Is virgin media able to provide me longer cable
if I pay for it ?
on 21-05-2022 21:19
on 24-05-2022 09:05
Hi @jmarek5,
As mentioned by @japitts and @jbrennand, we are unable to supply our Co-Axial cables directly to customers as they are specialist cable that form part of our network. For us to be able to get you a longer co-axial cable, we would need to book a Technician in, so they can install it. As previously mentioned, this would be at a one-time charge of £25.
I've sent over a PM to discuss this with you. Please look out in the top-right of our forums for the purple envelope.
Cheers,
