12-01-2021 11:41 - edited 12-01-2021 11:46
I’m so angry and frustrated with virgin. We upgraded to hub 4, 1Gig to try to increase WiFi speed during wfh and homeschooling. The existing boosters will not connect, so despite faster speed, the black spots upstairs still exist. I’ve followed the online set up and reset hun and boosters numerous times, they’re just dead. I just want the new Intelligent WiFi pods as part of our package to try to rectify. Can I get to speak to someone? No.
I have spent SEVEN HOURS on the phone to virgin this week, being passed from dept to dept with a 40 min wait each time. I have written on this forum - no response- have done the online triage/assistance 4x - no response- and have lodged a complaint, which i was told I’d be contacted within 48 hrs. Nothing. However if you call Sales, it’s a fast pickup as Virgin can make more money on this line.
Add to this endless online ‘troubleshooting’ links, which do not shoot my trouble.?
We’re paying considerably more for a poor WiFi service and ZERO customer service. I’m at my wits end. PLUS, a dead phone line for the past few weeks AND a failed hard drive on our V6 box, since replaced.
PLEASE help. I appreciate everyone’s struggling currently, but the customer service is horrendous. I just want to talk to someone who can fix what we’re paying more for! 😡
Answered! Go to Answer
on 14-01-2021 13:18
UPDATE:
Received the new intelligent WiFi pods and installed as directed. Following the activation text, I’ve been told they can’t be activated and to call tech support. I’m now on hold for 30 mins to Virgin tech, AGAIN!!
Utter RUBBISH.
on 14-01-2021 13:25
on 14-01-2021 13:34
Send it back and get your own better wireless kit
14-01-2021 14:09 - edited 14-01-2021 14:22
Interesting that these "new" Pods (according to the help docs) only work with Wifi Optimisation on and a single SSID for both channels. That should be fun for people who need a fixed channel and split SSID's for their IoT kit......
Also been on the Plume website and it's interesting use of the Cloud. However you can opt-out of certain things, but looks similar to Google and Amazon mesh AI. For the tin foil hat brigade it's maybe one to skip over. Personally I'd rather setup my own kit 🙂
on 14-01-2021 14:23
I wonder if they send any information or data to Plume as well. The “privacy policy” isn’t clear.
on 14-01-2021 14:25
The Pods have been designed (based on Plume) to be easy to set up (plug in and switch on) and use with the Hub 3/4 default configuration. They won't be suitable if you wish to depart from that default configuration. If you do you are going to have to use third party equipment if you want a Mesh system.
on 14-01-2021 14:30
Hi, I don’t wish to depart from anything, nor build my own mesh system nor split SSIDs. I don’t work in telecoms or IT. I simply want to plug in and get the service we’ve been promised and pay (more) for.
90 mins, 2 wrong departments and now the promise of a call back this afternoon. The call centre staff can only work with what they’ve been given admittedly, but it isn’t adequate.
The settings mentioned by another previously are all correct.
on 14-01-2021 14:40
Briony
Don't get too aggravated by the side discussions that take place in threads like this. The Forum is a means of sharing knowledge and information as well as offering direct help. But that help comes, more often than not from other VM users. The Forum is not a means of accessing VM tech help directly.
The first thing I would do is unplug the Pods or if they are already unplugged get one of them plugged in as near as the Hub as possible. See if it connects. If it does. Unplug it and reconnect it nearer the blackspot you wish to eliminate or improve.
If it doesn't then unplug it. Reboot your Hub and try again. The Hub does need to be running the latest version of the Hub software and this might bring it down.
If all that fails come back here and I'll push this up to the VM staff to get your account looked at. There is the possibility of a provisioning issue at VM's end. We need to find out.
on 14-01-2021 14:45
so what are the pods doing after you plug them in - they should start with a flashing white light which goes out after a while - the time seems to be variable mine went out in a minute or so - others report 5 minutes - if they are still flashing after 10 minutes i would say something is wrong
so if they are then do a reboot on the router and see what happens - if that does not help do a full reset and again see if that improves things
the hub4 needs new firmware to work with the pods - that is being rolled out - maybe yours has not been upgraded - can you log into it and post the firmware version
if after all that they do not work then post back and i or someone will flag the thread - not sure what the forum staff can do but we can ask
on 14-01-2021 15:02
The “service you pay for” is for wired speeds. Not wireless.
