Paul1762
Boardband Speed issues.
I am having an on going issue with the Boardband signal strength both wired and wifi... at times the speed is below 40mb,  my service is 220mb.
i know that my Macbook only has a 100mbs card inside, got that and would not expect above 100, however the wifi i would
the minimum service speed I should get is 107mb.
so when trying to resolve this last night i was told i needed a booster, well puzzled... as last week i was getting speeds of over 150mb, the router has not been moved, no more devices on the system.
so accepted a booster reluctantly... now This morning my service charge as changed to include a booster...
can anyone please explain why i have a degradation in my service provided... and the solution is for me to pay for something that is not needed and will not resolve the issue...
paul
  • 9.56K
  • 1K
  • 1.51K
Re: Boardband Speed issues.
Not necessarily !   For example, my Macbook Air and iPhone7 both get 220mbps on my Vivid200 wifi connection - but only when I put them onto the 5GHz network. Sat in the same spot if I then flick them over to the 2.4GHz network, they max out at 70-80mbps - it's just the limitations of the technology!  What network is your Macbook connecting too - if its not gigabit enabled I suspect it might also be limited to the "older" 2.4 GHz network standard and not have 5GHz capability.
  • 1.15K
  • 66
  • 212
Hi Paul1762,
Welcome to our forums and thank you for reaching out with your concerns. I'm sorry that you've experienced recent issues with your broadband connection.
Taking a look at the backend of your services, I've been unable to identify any issues with the connection entering your property. However there does appear to be a device or two which could be causing interference on your wireless network.
Is there anything near your hub which could be moved away or connected via ethernet instead of wifi?
I can also see that you've recently rebooted your hub, but have you tried a pinhole reset at all? I know it might seem simple, but it refreshes all internal processed and the connection to our network so will often resolve a lot of blips.
Regarding boosters, if you subscribe to the Full House package or above these would not be chargeable.
Rachael
Paul1762
J many thanks for the reply...
when you say network do you mean 1.4 or 5Gz?
my MacBook Pro is Mid 2014, iPad Pro and iPhone XR...
  • 9.56K
  • 1K
  • 1.51K
Paul - I was meaning.. can you tell from looking at iOS "network connection" or with a wifi scanner, whether your phone is connected on the 2.4 or 5 GHz networks at the time the speeds are "slow"?
I have separate SSID's for the 2 so its easy to tell or switch. If you have the Hub3 (you didnt say) and you havent renamed the SSID's they wont shop as separate.
Paul1762
J,
done what you suggest... now MacBook Pro show a cool 216.79 Mbps...
great...
many thanks
