  • 32
KPS
Blocking certain web sites on home network
Hi Guys Im using a SuperHUB 3.0 i want to block certain websites and ip address on my home network where would i go in the advance tab on my router to do that
KPS
  • 11.7K
  • 347
  • 678
Forum Team (Retired) Samantha_L
Re: Blocking certain web sites on home network
Hi KPS,
Thanks for posting and apologies for any inconvenience caused.
In regards to blocking certain websites, you are unable to do this through the router settings. You can use our Web Safe and take a look at the categories you can block.
If you want to be websites specific and IP address, you would need a security software to do that for you.
Sam
