  • 19
Talon
Message 11 of 22
Re: Best router for Hub 3 modem mode?
Hi, not an answer and slightly off topic i know but thought it was relevant. I read on these forums and in other publications of issues with the firmware of the hub 3 with regards to being used in modem mode. What is the up to date status of this problem.
  • 5.16K
  • 401
  • 854
Superstar
Message 12 of 22
Never had any troubles whatsoever when using the Hub3 in modem mode.
There are 10 types of people: those who understand binary and those who don't and F people out of 10 who do not understand hexadecimal
  • 1.67K
  • 93
  • 305
Super solver
Message 13 of 22
Like Tudor, I've never had any problems with Modem mode on any of the Hubs I've had.
Amble1
Message 14 of 22
Would this work on dual xbox ones if wired? I have NAT and IP issues using Hub 3 and two xbox ones, losing my hair!!
  • 5
msantos
Message 15 of 22
  • 10
UK_Guy
Message 16 of 22
I've been using a mesh of 3 Orbi's (1 RBK50 router & 2 satellites) since they were first released and the improvement to both wifi and general throughput is vastly better than when the Virgin was in router mode.
Cubecrazy
Message 17 of 22
Does the ASU’s dsl ac68u do it?
Can’t see if it is just for BT type internet fileteea! Or if one of the rj45 connectors will connect to the hub3 for the internet
  • 5.16K
  • 401
  • 854
Superstar
Message 18 of 22
As it’s got ‘dsl’ in its name it BT etc router with an internal ADSL modem. You need a general router or router/network switch/wireless access point.
  • 6
heavyend81
Message 19 of 22
It may have been resolved now but I went through all this about a year ago and the biggest issue I came across was the throughput speed of the Hub dropped significantly when in modem mode, I mean it was up to half the speed drop, but like I said it was a while ago I did this (with a £200 router which went back to Amazon for this reason). perhaps some on here would care to comment on this issue, if it is still an issue that is.
  • 21.77K
  • 620
  • 3.62K
Sephiroth
Message 20 of 22
I can 100% categorically state that Hub 3 throughput in modem mode will not be lower than your headline broadband speed.
A speed drop of that order, assuming the circuit to be fine and no serious contention from other users, must be down to the external router and/or how it’s configured.
you didn’t say whether your measurement was wired or wireless, btw.
