on 20-11-2021 09:55
Hi everyone,
I’m hoping someone can help because unfortunately VM support just “send signals to my router”…
since I’ve got my SH4 I have a weird issue where audio on calls intermittently drops out for a second or so at a time very often.
it happens on multiple devices AND multiple apps. Zoom, Teams, WhatsApp, FaceTime and WiFi Calling on my mobile are all affected.
The video part of the call works fine. It happens with headphones and inbuilt speakers. Streaming services work fine.
it’s completely infuriating and completely bizarre.
any advice or help would be massively appreciated.
cheers!
Answered! Go to Answer
on 22-11-2021 10:13
Choppy audio is usually caused by latency faults. Sometimes that may be internet routing to the relevant servers, sometimes on VM's local network. These types of fault do affect video as well, but if the video window is small or low resolution you might not notice.
Setup a Broadband Quality Monitor and post a LINK to a LIVE, SHARED graph here and we'll see what's happening. Usually needs to run for 24 hours before we can draw reasonable conclusions, but the live graph will continuously update so you can post the link immediately.
on 22-11-2021 10:02
Hello @comjl13,
Welcome to the community page, thanks for posting.
I am sorry to see you are having issues with audio calls.
Can you please tell me what device make and model this is happening on?
Many thanks,
on 22-11-2021 10:13
on 22-11-2021 10:13
@comjl13 wrote:<snip> any advice or help would be massively appreciated.
cheers!
Setup a BQM to monitor the state of your circuit. It's most likely latency, but the BQM will show up any problems.
on 22-11-2021 13:04
Thanks everyone - Thinks are improved today so maybe "signals..." worked?
I've set up the monitor (I think) so here's the link...
https://www.thinkbroadband.com/broadband/monitoring/quality/share/b879fc4679952a0c9906d0b7127a7ba950...
on 22-11-2021 14:26
If everything's working OK then that's good. As far as I can tell the "sending a signal to your router" pantomime probably does no more than remotely command a re-registration of the hub, such that it renegotiates all channels, usually picking nice "clean" frequencies. That can fix a one-off problem, it won't be an enduring fix for any power/noise faults which ultimately need physical intervention. Fingers crossed the problem doesn't return.
If the problem reappears you'll need to sort out the BQM - from the couple of hours now showing I can tell the BQM you've posted isn't tracking a VM DOCSIS connection.
on 24-11-2021 14:44
Hi @comjl13
Thanks for posting on our community forum!
How are you getting on with your connection today?
