on 24-08-2021 10:05
In the last 3 weeks or so WiFi in this area has been awful. I wonder if recent work has caused an issue? Problem is everyone thinks issue is unique to them. It isn't. Virgin likely to lose a lot of customers with Hey Broadband marketing strongly in the area.
Answered! Go to Answer
on 26-08-2021 16:49
Hi steveg440, thanks for getting in touch.
Sorry to hear about the issues you've had with your WiFi. I've taken a look into this using your forum info, and can see that there are some issues with the hub that may require the attention of an engineer.
Have a quick check of the connections to/from the hub and make sure there everything is snug & secure, and there are no kinks or pinching on the cabling. If things don't clear up please get back to me via PM and we'll be able to help further.
Tom
24-08-2021 10:32 - edited 24-08-2021 10:34
If problems are affecting your WiFi then it doesn't matter what provider you go with, you'll still get WiFi problems.
The best solutions is to connect to the hub with an ethernet cable instead.
Best you could also try using the 5 Ghz network instead which will not only be faster but less prone to interference.
on 24-08-2021 13:09
on 24-08-2021 15:58
By WiFi issues I mean that iPhones, iPad and Chromecast are either not picking up WiFi or are only getting it erratically. (I have 3 extenders in place.) I am also getting a new hub tomorrow as my existing one is dated - why are these not sent out automatically when they are upgraded?! Devices can be centimeters away from the hub and still not pick up WiFi. My comment about the upgrade is because it has got significantly worse in the last couple of weeks - so much so that notes have been put through doors asking if anyone else has WiFi issues with Virgin. No issues at all with the PC - ethernet connected or the printer which is also wired up. On the hub the top two lights are continually flashing as is the fourth one down. I have powered this down a number of times in the last week.
Steve
on 24-08-2021 15:59
The hub is connected with an ethernet cable.
on 24-08-2021 16:07
on 24-08-2021 16:08
I think a 3. I've got my fingers crossed!
on 26-08-2021 16:49
Tom
on 26-08-2021 17:04
Tom,
Thank you. I have just got a new Hub 3 and am waiting for my son to fit it.
Steve
on 26-08-2021 17:06
Tom,
I'll wait and see if the new Hub fixes the issue before I book an engineer.
Again, thank you.
Steve
