on 27-09-2021 10:05
Hi All,
I was wondering if anyone had a dummies guide to setting up my new Asus RT-AX89X router.
I have the 1Gig service with the SH4, I know how to set the router into modem mode, I just need a guide to setting the router up as the main router for the home.
All help appreciated.
Thanks in advance
Stephen
Answered! Go to Answer
on 28-09-2021 21:51
14-06-2022 13:45 - edited 14-06-2022 13:51
well my hub 3 seems to be acting a bit strangely in modem mode... I did a full reset, and left in router mode, then switched of all VM wifi...
I might have said this elsewhere, but...
set up your wiring how you want it (VM to WAN on ASUS, then i have one LAN cable to my old Netgear DS105 switch - the ASUS has no proper indication of speed or activity!! (there is a space on its LAN socket, but nothing there...)
switch off VM and ASUS for FIVE minutes! 😛 😛 then switch on ASUS, wait FIVE mins... THEN switch on VM, wait 5 mins or more for ASUS to asses the network..
I did the ASUS setup by using WiFi laptop.. IF you are not sure your setup is 'wifi 6' compatible' switch that OFF (you can go back later using the **settings backup** you make!!
