on 20-02-2021 14:19
Hi, I'm looking for a bit of advice on what's going to be best for me. I've got the 350 package with the Hub 3 and I'm looking for better speed and signal on WiFi but also a more consistent speed along the ethernet cable to my PC. I currently have some power line adapters/WiFi extenders that help to get some sort of a signal to the upstairs rooms however they're not the best and just about get me between 50-80mbps upstairs, it's not terrible but when I'm paying for 350, I want to try and get as much as I can. Apologies for going on.
Anyway, I've read up a little bit about the mesh systems and that seems to provide a better WiFi signal throughout the house but I'm not sure if that would be overkill considering I live in a terraced house. Would a better router make my WiFi signal better? I was on BT previously and the router seemed to work fine? If it's router you'd suggest then any recommendations? I think £200 would be my max budget but the cheaper the better?
Thanks in advance but the help
on 23-02-2021 09:16
If you've still got the old BT router - and the wifi performance was acceptable to you - you can use that.
