robincarter
Adding hub3 to network
Hi, I have 4 coax connections into 4 rooms if my home each with its own tvbox, so that each one can run independently. One of them is connected to a Hub 3.0 for broadband.
so each room can also have its own broadband connection I have purchased an additional Hub 3 and coax splitter but can not get the hub3 to connect to virgin media. How do I do this?
  • 22.54K
  • 2.41K
  • 4.03K
Re: Adding hub3 to network
You dont - you have bought an expensive door stop. VM will never activate a second Hub on your account - except in exceptional circumstances when you have 2 accounts and two subscriptions at your address and even then that Hub wouldnt be activated they would send you a new one.
You may be able to connect it to the first Hub by ethernet cable and use it as a wireless access point - but as the Hub3 has poor wifi - why on earth would you want to do that. You should get your monies back and get a wireless router or wireless access point or a Mesh system or some ethernet switches to wire in ethernet connections across the property
gary_dexter
  • 30.62K
  • 1.9K
  • 4.07K
Hubs are property of VM - any that are re-sold are stolen goods, which you are now in possession of
