on 25-02-2022 10:29
Could someone help me, I need to add a new network so I can run my ring doorbell and a security camera, ive been told it has to be 2.4htz as they won't run on 5htz
Answered! Go to Answer
on 25-02-2022 12:16
The VM hubs transmit both 2.4GHz and 5GHz on one SSID. If this does not work you can split it into two names like xxx-2 and xxx-5 in the hubs settings, also turn off smart/intelligent WiFi. Unfortunately if you have VM pods you cannot do this.
on 25-02-2022 12:16
