  • 8
Steff1968
Message 1 of 8
Achieve Full Speed In Safe Mode Only !!!
Had posted yesterday about slow download speeds on my Vivid 350.
Contacted support today.
Was advised to test speed in Safe Mode  .... (389 Mbps)
So the issue is with me and my PC it seems .
Have disabled firewalls and Anti Virus.
Ran malware programs and some DNS Flush program but results are still around half speed in normal mode.
Anybody out there know anyelse I could try.
TiA
  • 7.25K
  • 756
  • 1.13K
Legend
Message 2 of 8
Re: Achieve Full Speed In Safe Mode Only !!!
Is it a Dell? They often seem to run "SmartByte" in the background which "manages traffic".  Try alternative browsers - they might have become "infected".
Or this...  see last post.
https://community.virginmedia.com/t5/Speed/Slow-speed/td-p/3896582
  • 12.68K
  • 968
  • 2.88K
Message 3 of 8
there was a banking app many moons ago that was a problem - certain versions of Malwarebytes has also been seen to cause slow BB
if its neither of those or the Dell software sighted above then start with drivers for the lan card - look for older/newer ones and see if that helps
the only real method if its not drivers is reinsall your OS and add stuff checking the speed at each point
easy way is start with a clean harddrive after removing the one thats in there at the moment - once you find the problem put the old drive back in and delete whats ever is the problem
if you dont have a spare harddrive backup what you have to a safe area and delete stuff one program at a time - once you have the problem put the backup back on and again delete the problem
____________________
Tony
  • 8
Steff1968
Message 4 of 8
Thanks Tony.
Obviously would like to avoid a full restore if possible... But we'll see.
Malwarebytes was only just installed to see if it helped find anything.
Its a custom built PC so no Dell etc.
Will try selective startup and see what can be deselected... Just don't want to untick something that I shouldn't... 😂😂😂
  • 7.25K
  • 756
  • 1.13K
Legend
Message 5 of 8
In the link I posted the user had custom built his PC and it came with TurboLAN on the motherboard - which he identified was causing the problem
  • 8
Steff1968
Message 6 of 8
Missed your first post mate.
Will have a look to see if that's the issue.
Not sure if I have TurboLAN... Or similar
Had the same PC for a few years and has been fine.
Thanks again 👍👍👍
  • 11.49K
  • 1.05K
  • 2.46K
griffin
Message 7 of 8
I would try another freshly installed browser to rule out any browser extensions casing issues.
  • 8
Steff1968
Message 8 of 8
Have reinstalled windows and now everything runs as it should.
Its been years since I've installed windows so it was well overdue.
I was actually surprised with how easy and pain-free the install was.
Thanks all
