  • 63
Quinn
Message 11 of 21
Re: A few issues I would like to solve finally
Just checked network log, is this a concern?
2018-11-27 19:05:55.00Warning!RCS Partial Service;CM-MAC=
2018-11-28 04:43:44.00criticalNo Ranging Response received - T3 time-out;CM-MAC=
2018-11-28 12:53:59.00Warning!RCS Partial Service;CM-MAC=
2018-12-01 12:19:34.00ErrorDHCP RENEW sent - No response for IPv4;CM-CMTS-MAC=
2018-12-01 13:16:19.00Warning!
CMTS-MAC=
2018-12-01 17:04:02.00critical
-MAC=
2018-12-01 17:40:44.00Warning!
CMTS-MAC=
2018-12-02 00:43:57.00Error
DHCP RENEW sent - No response for IPv4;CM-MAC=
-MAC=
2018-12-02 04:04:10.00Warning!
CMTS-MAC=
2018-12-02 06:56:08.00Error
CMTS-MAC=
2018-12-02 11:42:24.00Warning!
CMTS-MAC=
2018-12-02 12:21:48.00Error
CMTS-MAC=
2018-12-02 13:08:22.00Error
DHCP REBIND WARNING - Field invalid in response;CM-MAC=
CMTS-MAC=
2018-12-02 15:02:01.00Warning!
CMTS-MAC=
2018-12-03 17:11:59.00critical
CMTS-MAC=
2018-12-03 17:37:50.00Warning!
CMTS-MAC=
2018-12-05 08:22:58.00critical
CMTS-MAC=
2018-12-05 14:16:58.00Warning!
CMTS-MAC=
1970-01-01 00:01:35.00critical
CMTS-MAC=
2018-12-05 21:20:06.00Warning!RCS Partial Service;CM-MAC=CMTS-MAC=
Mac address/numbers removed Smiley Happy
  • 143
  • 40
carnivalist
Superfast
Message 12 of 21
@Quinn wrote:
To be fair Virgin have been great for me and I have been with them for will over 12 years.
Just these annoyances I want to try and solve, perhaps some settings in the modem/router settings or something minor that can be done just to improve it!
I've been with them through the NTL/Telewest/Blueyonder eras and their broadband has always been rock solid. In fact it's probably the one thing that has kept me from leaving during earlier eras, especially when Virgin first took over when the company was infuriating in many other respects. It did seem to be the case that some years ago Virgin Media upped their game in various areas compared with their former failings  - and noticeably so by comparison with the infuriating Virgin Mobile - but in recent months the broadband seems to have gone over a cliff for some reason.
  • 63
Quinn
Message 13 of 21
Network log posted above, upstream and downstream here. Bear in mind it is performing OK tonight...
Upstream
14620000046.5512016 qam57
22580000046.3512016 qam60
33260000046.3512016 qam59
43940000046.8512016 qam58
3ATDMA0000
4ATDMA0000
Downstream
1203000000-2.540256 qam9
2483000000-4.540256 qam30
3475000000-4.440256 qam29
4467000000-4.540256 qam28
5459000000-540256 qam27
6451000000-4.540256 qam26
7443000000-4.240256 qam25
8323000000-3.540256 qam24
9315000000-3.540256 qam23
10307000000-3.540256 qam22
11299000000-340256 qam21
12291000000-3.440256 qam20
13283000000-340256 qam19
14275000000-340256 qam18
15267000000-340256 qam17
16259000000-3.240256 qam16
17251000000-3.240256 qam15
18243000000-340256 qam14
19235000000-340256 qam13
20227000000-2.738256 qam12
21219000000-2.740256 qam11
22211000000-2.740256 qam10
23195000000-2.240256 qam8
24187000000-2.240256 qam7
1Locked40.31291486
2Locked40.3184209
3Locked40.9199334
4Locked40.3254251
5Locked40.3265271
6Locked40.3180268
7Locked40.3241245
8Locked40.3260452
9Locked40.9284472
10Locked40.3343343
11Locked40.3442508
12Locked40.3445308
13Locked40.9356278
14Locked40.9463558
15Locked40.3445453
16Locked40.3445463
17Locked40.3452459
18Locked40.3660454
19Locked40.31905443
20Locked38.69334565
21Locked40.3774370
22Locked40.3520400
23Locked40.32518536
24Locked40.317128199
  • 1.83K
  • 103
  • 290
chenks
Super solver
Message 14 of 21
@Quinn wrote:
I am just doing various speedtests, they are all over the place from various sources.
Speedtest.net starts high (350mb to 400mb) but declines constantly and ends on around 60mb by time it has finished. Something must be off.
I will get a picture of the outside connections when it is light, they do look a bit sketchy...
you should only do them via ethernet connection.
WIFI can skew the results if the WIFI network has issues (as you stated in point 1).
  • 1.67K
  • 93
  • 305
Super solver
Message 15 of 21
T3'a are okay if they rise slowly. If the numbers are in the hundreds over a few days, then that is a problem. So, just keep an eye on those.
The power levels are close to the bottom of acceptable range, they should be between -6 and +10, so you are borderline.  If there are any attenuators on the line, you could try removing them and see if the levels rise.  If not, just put them back.
Agree about the WiFi, it's not the best for speed testing as it's reliant on the environment at any given time.  If you have an Android phone, get a WiFi analyser app and walk about the house and check for best WiFi spots.
Have you updated your Linksys firmware to the latest version, as this can improve security and performance and I would recommend you do this.
Also consider a TBB graph  www.thinkbroadband.com/ping  this will show any dropouts on the circuit.
  • 63
Quinn
Message 16 of 21
Hi, my speedtests ARE ALL via ethernet on my PC, none are via wifi. I should have clarified. I only test via ethernet.
What is an attenuator? If I have some and removing them don't work then what as you say my power levels are borderline.
My Linksys and superhub is always kept up to date with firmware, these issues started with superhub 3.
I actually have been tracking my ping etc from TBB, here is the results from yesterday...
  • 63
Quinn
Message 17 of 21
Additionally here is the outside box/wiring. Main connectors are finger tight...
  • 63
Quinn
Message 18 of 21
Any further advice from anybody please?
  • 15.2K
  • 653
  • 32
Moderator (Retired) John_G
Moderator (Retired)
Message 19 of 21
Hi Quinn,
Sorry to hear you're getting drop outs. I've just checked your connection and can see no problems from here. Your power levels, SNR and area contention all look healthy.
Do you only get these drops with your router connected or direct to the hub too?
  • 63
Quinn
Message 20 of 21
Thank you for the reply...
I am glad everything looks healthy on your end. Ironically since making this post things have been the best they have been for months with my connection. I have had one complete internet drop out on wired and wireless but I reset the modem and router and it has been fine since that.
I changed a few settings in the Linksys admin control panel as per some youtube instructions and the wifi seems to be stronger now.
