5GHz lost connection
WeeJDoh
So all of a sudden last night our devices lost connection and it appears the 5GHz connection isn't working anymore. 2.4 is fine but it's been a pain having to log everything over to that. I've rebooted and pinhole reset the Hub 4 but it's still not resolved.
Any ideas what could have happened?
1 REPLY 1
Alex_RM
Hi WeeJDoh,
Thanks for posting, and sorry to see you're having some connection issues.
Thank you for trying a pin-hole reset already. I've had a look at things from our side, and our systems are advising reverting the split SSIDs back to 1 SSID will help improve the wireless performance within the home.
Are you able to try this?
Alex_Rm
