2g wifi
I have kindle also Alexa also Samsung galaxy phone which now don't work on virgin 2g Wi-Fi and on phoning 150 with virgin told need to get on 5g WIFI. Which my phone does not have or my kindle. my play station 4 works ok on 2g Wi-Fi . My issue is I am paying for Wi-Fi and now its not working. One thing I've read is too many people on Wi-Fi system can not cope,
  • 15.68K
  • 1.64K
  • 2.68K
Re: 2g wifi
Ignore what VM CS says.
Firstly what Hub model do you have (printed on its sticker). Try a pinhole reset and see if that restores the wifi bands
  • 6.71K
  • 502
  • 876
Legend
Re: 2g wifi
Try this ...
DO NOT DO THIS if the password on the base of the Hub is not legible or missing.
Instructions for Hub 3
Disconnect all unneeded ethernet cables from the rear of the Hub.
With the Hub Powered on use a paperclip or similar and do a pinhole reset.
DO NOT reboot the hub but allow it 5 to 10 minutes for it to boot itself up.
Once a steady white and no other lights are illuminated check your system again.
Then
You may be as well refining your Wi-Fi management, it will certainly help keeping track of your Wi-Fi frequencies.
Best done with a cable connected device.
Log in to the Hub.
Advanced Settings > Wireless > Security > Add 2 to the 2.4GHz Channel name > Add 5 to the 5 GHz Channel name > Click ‘Apply Changes’
Log out of the Hub.
You will need to reconnect all you Wi-Fi devices some will want to connect to 5Ghz and some to 2.4GHz and some will connect to either.
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
