on 12-06-2022 16:36
i have read on the vm website that i can upgrade from my 2ac hub (the wifi keeps dropping out, i have tried to reset it but and still getting the same problem) to a hub 3 for free, when i do what they advise i keep getting taken to a chat page that doesn't seem to work, can anyone help ?
when i called 150, they told me there would be a charge as it was an on-line offer to have a free upgrade
Answered! Go to Answer
on 12-06-2022 18:23
12-06-2022 16:43 - edited 12-06-2022 16:43
I posted this the other day....
_______________________
Because the webpage is years out of date and not working properly - the offer still shows.
However, VM (like others) have a Hub stock shortage at the moment and essentially are not swapping hubs unless they are faulty - or if a customer moves to a package that requires a different Hub. In your case - the SH2 is good for up to 200 - anything higher requires them to give you a Hub3/4. A new package will cost more and start a new 18 month contract
I still use the SH2 albeit in modem mode. So why do you want to change it ?
I would say if it aint broke dont try and fix it.
on 12-06-2022 16:50
on 12-06-2022 16:53
on 12-06-2022 16:58
on 12-06-2022 18:23
on 12-06-2022 18:52
thanks, to be honest i only use the pc, but the kids and grandkids are the ones on the wifi, and they are on my case.
I don't think i can take calling vm again, takes me an age just to pick the right option to try to get through to the right person and then they just want to sell me something, seriously thinking of paying £20 for a replacement from ebay.
many thanks for your time
12-06-2022 22:55 - edited 12-06-2022 22:56
Any VM equipment you buy on eBay is a door stop - VM will never reactivate anything to work on your account.
If you want to spend a small amount of money see these options...
https://www.amazon.co.uk/Tenda-AC8-Wireless-Supports-management/dp/B07Z7NY23Q/
or
https://www.amazon.co.uk/Archer-C6-Wireless-Supports-Parental/dp/B07L5YRYF4/
or with MU MIMO wifi
https://www.amazon.co.uk/Tenda-AC10-1200MBPS-DUALBAND-ROUTER/dp/B07DGPYKLP/
on 13-06-2022 13:52
Hi John
am i right in thinking i change my 2av from router to modem mode then just plug into new wireless router ? and would i need to plug the ethernet cable for my pc and hive box into the new wireless router or leave in the 2ac ?
much appreciate your help
Ken
13-06-2022 16:21 - edited 13-06-2022 16:23
Basically yes. There is a sequence to follow if you get one - I have posted it below.
When in modem mode only 1 port on the Hub works and the others shut off. So that is the port you use for the router. On the SH2 I think it's the "bottom" one that works - my router is in that port anyway. That's the port you use to connect the router to. Any other ethernet connections then have to emanate from your router - and there are 4 LAN ports on them specifically for that use. When its set up as below plug the PC/Hive into those.
_______________________________________________________________
Switch on and set up your own router (in its settings) to have the WAN port set to be in Automatic IP i.e. DHCP (& Nat) mode, it may be pre-set that way anyway, but the instructions should walk you through it.
Also you might want to set the 2.4 an 5 GHz SSID's names and the Wifi passwords on the new router to match that on your Hub so when you swap over, all your wireless devices should just connect automatically.
Once set, disconnect all cables from your new router and switch it off and unplug it. Then, put the VM Hub into modem mode as per...
https://www.virginmedia.com/help/virgin-media-hub-modem-mode
...and leave it 5' to settle. Once it’s in modem mode, the VM hub “MUST” then be powered off.
Switch your router on and make sure it’s fully initialised (leave 5 min) and then put in the ethernet cable from its WAN port to the VM hub. As I said I think its the bottom one.
NOW… power up the VM hub and wait 5-10 minutes for The Hub to initialise and and you should get a connection.
This order only needs to be done the first time you connect the router to the VM hub.
