  • 5
Message 1 of 10
200 MG speed query.
Having upgraded recently from 100 to 200, my speed is ranging from a pathetic 18-24 the entire evening. Help!
  • 651
  • 120
  • 204
Message 2 of 10
Re: 200 MG speed query.
Hi, can you try a pinhole reset as sometimes the hub doesn't take the update.  Press the reset button in on the back of the hub for 20 seconds then release for 5.  Repeat this 3 times.
Also try resetting network settings on your devices
Rich
Send Me a PM!
Here to help! I'm a Field Technician helping out from home. Find out more
REFER A FRIEND AND SHARE £100 BETWEEN YOU
****************** ASK ME HOW ******************
  • 14.29K
  • 591
  • 1.37K
Message 3 of 10
Because one reset is not enough or dose it send a signal to CMTS saying more bandwidth to this modem.🤔
If you have a super hub 1 you will need a new hub for 200Mb.
  • 651
  • 120
  • 204
Message 4 of 10
The hub takes an update when package is changed. I didn't know you had already tried a 20sec x3 factory reset sorry
Rich
Send Me a PM!
  • 14.29K
  • 591
  • 1.37K
Message 5 of 10
I wouldn't know I'm not the other person!
  • 5
Message 6 of 10
Thanks for speedy reply, no luck yet but will keep trying for a bit
  • 5
Message 7 of 10
Thanks for answer, no luck yet but will try a bit longer.
  • 5
Message 8 of 10
Thanks for suggestions, no luck yet, might be a Glasgow thing. Cheers.
  • 14.29K
  • 591
  • 1.37K
Message 9 of 10
Check your Operation Configuration in the hub for Max Traffic Rate.
  • 5
Message 10 of 10
Thanks for the reply, I’m afraid that looks beyond my tech knowledge.
