  • 4.61K
  • 309
  • 770
Roger_Gooner
Superstar
Message 11 of 24
Re: 2.4 Ghz cannot get IP address - need it for Ring 2 doorbell and Canary camera
The problem with having a fixed IP address is that most people won't understand this, and there is still the issue of a weak 2.4GHz WiFi connection which may persist even if you get your own router.
A better - but much more expensive - option is the Video Doorbell Elite which supports Ethernet, and it's PoE as well.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 10
sophiestree
Message 12 of 24
Wow! I just looked those doorbells up, they are £450.... 3 times as much, which I certainly couldn't afford.
I'm puzzled, from what I have looked up everywhere,  why,  if everyone knows it is the Hub 3 router that has the issues,  why it is not replaced? I pay a lot of money for a fast broadband speed and it now keeps dropping out, stops for a day or even two and now this.
How is that ok?
It also seems a decent router, if I were to do what a previous person suggested from Virgin,  is about £180.
  • 10
sophiestree
Message 13 of 24
has this been reported as solved?
I don't feel I have a solution at all
  • 1.31K
  • 72
  • 93
Message 14 of 24
Hi sophiestree,
Can you please confirm if you've performed a pin hole reset as previously mentioned?
Alex_Rm
  • 10
sophiestree
Message 15 of 24
I did, exactly that
And now the internet constantly drops out. It is even worse than it was before
  • 1.31K
  • 72
  • 93
Message 16 of 24
Thanks for confirming,
Is it just these two devices that are struggling to connect to the WiFi?
Alex_Rm
  • 10
sophiestree
Message 17 of 24
No, now I have done the pin reset - everything is dropping out - on my phone, on my laptop, on NowTV
It has become untenable.
  • 1.31K
  • 72
  • 93
Message 18 of 24
I'm not able to locate any details for you sophiestree in order to run a health check on your account,
I've popped you over a private message so I can get a few more details from you.
Alex_Rm
  • 12.54K
  • 480
  • 1.12K
Message 19 of 24
A health check for a wireless issue should be interesting...
  • 11.8K
  • 1.08K
  • 2.56K
griffin
Message 20 of 24
Who said they were doing a wireless health check?
Wouldn't it be prudent to check the local circuit as "every thing is dropping out"
