24-01-2022 16:10 - edited 24-01-2022 16:15
Had an email offering an upgrade to 1gb and a Hub 4 (ultimate volt customer), at the moment I have M600 and Hub 3. My service has been excellent for many years and so I am hesitating whether to take the offer or not. What is the general consensus on the reliability of the 1gb BB service and the Hub 4, I should add that I will only use the hub in modem mode.
26-01-2022 22:46 - edited 26-01-2022 22:50
Hub 4 arrived today, I'm super nervous about installing it though as my existing hub 3 has not given me any issues (touch wood)!
on 02-02-2022 16:53
Is the hub 4 worth installing is now a moot point as last night (23:15ish) VM very nicely disconnected my hub 3 without telling me and then sent an SMS this morning telling me that my hub 4 has been registered. I hadn't installed the hub4 so I'm not sure how they registered it. However I have now installed the hub 4 and thankfully it is working ok so far, the hub is in modem mode and the only issue is that I can not access the admin pages, the hub 3 in modem mode didn't have this issue so I don't know what's up.
on 02-02-2022 16:55
on 02-02-2022 16:58
@gary_dexter wrote:
192.168.100.1 is the address to access the admin pages in modem mode
I know, it doesn't work. ☹️
on 02-02-2022 16:59
on 02-02-2022 17:13
@jbrennand wrote:
Dont send the Hub3 back for a while until you have test driven the Hub4 for a good period. Will make it easy to go back if issues arise
Good idea, the hub3 is not going anywhere just yet.
on 02-02-2022 18:01
I would point out that the Hub 3 can't handle the one Gig broadband tier (only the 4 and 5 can), so the only way to be able to use the old Hub 3 is to revert back to the highest speed that the 3 can use, which is 600 Mb/s.
Now the problem, as I see it, might be that if the upgrade was part of a 'Volt' uplift, then I do wonder how well VM's back end system and customer services with their legendary* efficiency and flexibility will cope with such a request.
* In the literal sense, ie doesn't actually exist.
on 02-02-2022 20:13
If have had the problem of connecting to 192.168.100.1 numerous times, what fixes it for me is to just unplug the cable between the VM hub and my UDM Pro router, wait 20 seconds and plug it back in again. It then works.
on 02-02-2022 20:30
@Tudor wrote:If have had the problem of connecting to 192.168.100.1 numerous times, what fixes it for me is to just unplug the cable between the VM hub and my UDM Pro router, wait 20 seconds and plug it back in again. It then works.
Thanks, I will try that tomorrow.
