on 05-02-2022 13:45
After many hours calling VM with no sucsess, to reconnect extension,or answering machine I found you need to parallel two output lines into the line comming from port one/line 1 on the router/modem, ond no splitter seems to exist , with the correct connector, to the devices
05-02-2022 14:18 - edited 05-02-2022 14:22
VM are not responsible for extension wiring. The only thing they will do at 21CV switchover (if specifically requested at the time) is to directly wire the existing PSTN master socket to the back of the hub. Any wiring from the master socket onward is the customers responsibility.
See the answer to a similar query below:
on 05-02-2022 15:43
Hi @howy_c,
Welcome back to our Community Forums! Thank you for your post, and I'm sorry to hear that you're having some issues with your answering machine.
I understand that the new 21CV switchover can be frustrating in comparison to the old copper line. You can read more about this process here: Home Phone Switchover.
Please let us know if you have any further questions about this process, we'll be more than happy to assist.
Thank you.
on 05-02-2022 16:17
this fix works,i am afraid there was no helpful information on the vigin site, and i can see chos looming for the older and less tech savvy customers
on 05-02-2022 16:36
Hi @howy_c,
Thanks for coming back to me about your landline issue. I'm glad to hear that you're able to have this resolved.
I'm sorry to hear that you fell this way. We're always here if you or anyone else have any further questions about the landline switchover.
Let us know if there's anything else we can do to help.
Thank you.
