Hi @nishia,
Thanks for your reply. I've located the account using your forums information just to check things over and I can see that your telephone services are using our DOCSIS technology - this means that the telephone services are only available through the direct connection to the hub.
This will explain why the dial tone does not work when connected to the other sockets.
Let me know if you have any further questions.
Kind regards,
