on 28-02-2023 13:02
Hi - I've recently been "migrated" to fibre phone. I've plugged my old landline phone into by hub (Super Hub 2), via the virgin adaptor.
The phone remains completely dead, however. No dial tone at all.
I'm guessing I need a newer hub. I'd be grateful for any suggestions.
Answered! Go to Answer
on 28-02-2023 13:06
A Hub(3/4/5) is required for the VOIP phone, these have a couple of TEL sockets.
Disconnect the phone adaptor from the Hub 2 that is not going to work.
on 28-02-2023 13:06
on 28-02-2023 13:09
Hi - thank you for your answer. How do I go about getting the required hub?
Thanks.
on 28-02-2023 13:12
Hello Eddy99
Sorry to hear of the landline issues since the migration to your Hub, we appreciate the confusion this can cause and you taking the time to raise this via the forums.
As Client62 has advised, the migration to the landline working via the Hub relies on a Hub 3, Hub 4 or Hub 5 to support the service. In order for this to work we will need to update the Hub, I will send you a Private Message to get some details from you to arrange this and look forward to hearing back form you.
Rob
28-02-2023 13:19 - edited 28-02-2023 13:20
Looks like help is on hand already !
on 28-02-2023 13:27
If you check the top right when signed in Eddy99, there should be a purple envelope where you can find my Private Message when signed into the forums 🙂
Rob
