on 09-02-2023 20:36
Using my landline, mobile and son’s mobile, even away from home, we cannot connect to most landline numbers. Mobile numbers appear ok and also the odd landline number but the majority just has a dead line our end but seemingly the other person hears the call ring but when tries to answer it doesn’t connect.
Answered! Go to Answer
on 10-02-2023 09:34
on 10-02-2023 09:39
on 10-02-2023 09:50
Hi GROBTIV,
Thanks for coming back again on this.
It looks as though you and the OP are in the same area so I am going to raise this further with the mods to look into. We may need some more information from you but I can see that you're in a private discussion with Gareth so if we do, we will let you know there.
For now, leave this with us and we'll be back in touch shortly.
Many thanks,
on 10-02-2023 09:53
on 10-02-2023 11:47
Hi GROBTIV,
Thanks for your patience.
The teams have looked into this and found no issues our end. There also hasn't been any spike in faults being reported so for now these are to be treated as single user issues.
I can see you're already in a private conversation with Gareth so he will continue there for now while I wait for the OP to reply.
Many thanks,
on 10-02-2023 13:51
Same I'm having the same issues here since upgrading too the Virgin HUB FIVE where I have too call the number several times before being connected too the destination I'm calling?
Kind regards
Dean 👍 👍 👍
on 10-02-2023 14:15
Hi dmason197,
Thanks for taking the time to post about your issues in the Community. ⭐
We're sorry to hear you're having trouble getting through. Do you notice this happening on one particular landline number or is this the same regardless of the number you try.
What tone do you get when trying to make the call?
You've mentioned that it does work after trying multiple times - do you do anything different or just dial the number?
Pop back and let us know so we can help further.
Many thanks,
on 10-02-2023 14:38
Kath
I just have too redial the number multiple times and It works
However this happens on most calls regardless of the time of day or night
Its very frustrating Its like a dead tone I get when dialling out
Kind regards
Dean
on 10-02-2023 15:11
I don’t get through at all and just get dead line.
on 10-02-2023 15:15
Hi dmason197,
Thanks for coming back to me further on this one.
Checking our systems, I can see that there is a fault open that is affecting you. The details of that are here:
I have made a note of this on your account so the relevant teams are aware you are affected and this will ensure the account is assessed automatically for automatic compensation once the fault is closed as resolved.
If there is anything else we can do, let us know.
