on 21-06-2024 17:10
I have had a landline included in my contract for many years which I haven't used; I've been using an existing BT account instead. I've decided to cancel the BT account. Can I plug my BT phone into the Hub TEL port and if so what plug adapter do I need - BT plug female to RJ11 male?
The only Virgin wall socket I have with a telephone socket is old and no longer in use - it doesn't produce a dial tone when i plug into it.
on 21-06-2024 17:20
Hello mickcoppard
Thanks for posting in regards to your landline and using this via your Hub, we appreciate you raising this and welcome to the community.
I will send you a Private Message to get some more details from you to assist. Check the envelope in the top right of the forum when signed in for the message.
Rob
