  • 69
cathowen3
Message 1 of 7
Noise on incoming calls
Every now and then we and our neighbour encounter screeching noises on our phones. Do you have any suggestions as to what might be causing this?
  • 1.03K
  • 48
  • 91
Moderator
Moderator
Message 2 of 7
Re: Noise on incoming calls
Hi cathowen3,
Thanks for your post.
Very sorry to hear you are having trouble with your landlines. Is this when you are making or receiving a call?
Do you have cordless phones? If you do, do you have more than one and is this happening on all handsets?
Lindsey_C
  • 69
cathowen3
Message 3 of 7
Hi Lindsey
we have corded and cordless phones but we don’t use the cordless phones. We have  a large house and just used these as a loudspeaker.  We have two corded phones & this happens on both. It doesn’t happen all the time .
  • 1.03K
  • 48
  • 91
Moderator
Moderator
Message 4 of 7
Thanks for explaining this for me. Does it happen when you are making or receiving calls or a combination?
Lindsey_C
  • 69
cathowen3
Message 5 of 7
It happens on both. For the past few days it’s been ok. It’s very unpredictable.
  • 962
  • 49
  • 130
Message 6 of 7
Thanks for confirming. I think we'll need to go through some checks on your account to try & establish what's causing this.
I'll send a PM shortly to get some details & will look forward to hearing back from you.
Tom_F
  • 69
cathowen3
Message 7 of 7
Typing error on previous message
Prescot not Prescott
