on 11-05-2022 20:59
Hello my landline keep disconnecting phone calls at random as I phone 150 today twice my landline disconnect both calls not sure why
on 12-05-2022 10:19
I will when I get home
on 12-05-2022 10:53
No problem.
Cheers,
Ryan.
on 12-05-2022 13:34
Acquired Downstream Channel (Hz) | 331000000 | Locked |
Ranged Upstream Channel (Hz) | 60300009 | Locked |
Provisioning State | Online |
on 12-05-2022 13:34
1 | 331000000 | 5.6 | 40 | 256 qam | 25 |
2 | 203000000 | 5.8 | 40 | 256 qam | 9 |
3 | 211000000 | 5.5 | 40 | 256 qam | 10 |
4 | 219000000 | 5.3 | 40 | 256 qam | 11 |
5 | 227000000 | 5 | 40 | 256 qam | 12 |
6 | 235000000 | 4.9 | 40 | 256 qam | 13 |
7 | 243000000 | 4.8 | 40 | 256 qam | 14 |
8 | 251000000 | 4.9 | 40 | 256 qam | 15 |
9 | 259000000 | 4.6 | 40 | 256 qam | 16 |
10 | 267000000 | 4.5 | 40 | 256 qam | 17 |
11 | 275000000 | 4.5 | 40 | 256 qam | 18 |
12 | 283000000 | 4.5 | 40 | 256 qam | 19 |
13 | 291000000 | 4.5 | 40 | 256 qam | 20 |
14 | 299000000 | 4.6 | 40 | 256 qam | 21 |
15 | 307000000 | 4.8 | 40 | 256 qam | 22 |
16 | 315000000 | 5.1 | 40 | 256 qam | 23 |
17 | 323000000 | 5.5 | 40 | 256 qam | 24 |
18 | 339000000 | 5.8 | 40 | 256 qam | 26 |
19 | 347000000 | 5.9 | 40 | 256 qam | 27 |
20 | 355000000 | 5.8 | 40 | 256 qam | 28 |
21 | 363000000 | 5.8 | 40 | 256 qam | 29 |
22 | 371000000 | 5.6 | 40 | 256 qam | 30 |
23 | 379000000 | 5.5 | 40 | 256 qam | 31 |
24 | 387000000 | 5.1 | 40 | 256 qam | 32 |
1 | Locked | 40.9 | 26 | 0 |
2 | Locked | 40.3 | 11 | 0 |
3 | Locked | 40.9 | 13 | 0 |
4 | Locked | 40.3 | 9 | 0 |
5 | Locked | 40.3 | 18 | 0 |
6 | Locked | 40.3 | 10 | 0 |
7 | Locked | 40.3 | 12 | 0 |
8 | Locked | 40.3 | 17 | 0 |
9 | Locked | 40.3 | 8 | 0 |
10 | Locked | 40.9 | 16 | 0 |
11 | Locked | 40.9 | 11 | 0 |
12 | Locked | 40.9 | 15 | 0 |
13 | Locked | 40.3 | 12 | 0 |
14 | Locked | 40.9 | 13 | 0 |
15 | Locked | 40.9 | 12 | 0 |
16 | Locked | 40.9 | 14 | 0 |
17 | Locked | 40.9 | 11 | 0 |
18 | Locked | 40.9 | 23 | 0 |
19 | Locked | 40.9 | 25 | 0 |
20 | Locked | 40.9 | 23 | 0 |
21 | Locked | 40.9 | 37 | 0 |
22 | Locked | 40.9 | 12 | 0 |
23 | Locked | 40.3 | 10 | 0 |
24 | Locked | 40.3 | 3 | 0 |
on 12-05-2022 13:35
1 | 60300009 | 48.8 | 5120 | 64 qam | 1 |
2 | 39399986 | 47.3 | 5120 | 64 qam | 4 |
3 | 46199979 | 48.8 | 5120 | 64 qam | 3 |
4 | 53700031 | 48.8 | 5120 | 64 qam | 2 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 |
on 12-05-2022 13:35
Network access | Allowed |
Maximum Number of CPEs | 1 |
Baseline Privacy | Enabled |
DOCSIS Mode | Docsis30 |
Config file | dJKDHSUBsgvca69834ncxv987 |
SFID | 29139 |
Max Traffic Rate | 575000000 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
SFID | 29097 |
Max Traffic Rate | 38520000 |
Max Concatenated Burst | 16320 |
Scheduling Type | BestEffort |
on 12-05-2022 13:36
12/05/2022 12:28:58 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/05/2022 08:15:22 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/05/2022 20:01:34 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/05/2022 19:54:18 | notice | Unit has been restored to factory defaults from a software issued command;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/05/2022 14:42:38 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/05/2022 22:10:15 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/05/2022 14:04:29 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/05/2022 07:53:37 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/05/2022 21:49:42 | notice | Unit has been restored to factory defaults from a software issued command;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/05/2022 21:48:57 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/05/2022 07:39:4 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/05/2022 01:47:3 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/05/2022 01:47:3 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/05/2022 00:40:24 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/05/2022 14:38:45 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/05/2022 04:31:39 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/05/2022 16:24:6 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/05/2022 15:43:12 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/05/2022 13:37:27 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/05/2022 09:27:31 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 12-05-2022 15:17
I have checked from our side also and there is nothing that stands out.
I can see you have spoken with Paul on a previous post back in April about the same thing and he had asked about putting the hub into modem mode to see if there is any difference. Was you able to complete what was advised?
Cheers,
Ryan.
on 12-05-2022 16:04
yes same results 120mbps
on 12-05-2022 16:56
Hi @sandelben,
Thank you for coming back to us in regards to your ongoing speed issue. I'm sorry to hear that your speeds are still showing as slow in comparison to your package.
Have you been able to take a look at our Speed Up page to see if this can help?
After running some internal checks on our systems, I cannot see any power level issues that would be impacting your speeds.
Do you have an alternative Ethernet cable to try out to see if the speeds change at all?
Let us know how you get on.
Thank you.
