on 12-08-2022 16:10
This is a strange one, so wondering if anyone else has observed something like this...
With the home phone plugged into the Hub 5, I am seeing frequent missed calls from 'No number' at a variety of times during the day. But if I call 1471 I am getting call data older than this (which relate to 'real' calls), so seems like we are getting spurious missed call data to the phone from the Hub.
Has anyone else observed anything similar?
29-09-2022 20:47 - edited 29-09-2022 21:11
@Mercman123 wrote:Hi All, we had a hub 4 replaced with a hub 5 on Saturday 24th September, and ever since we get random no number calls showing on our habd set today ir was 27, the timings are always at a time with a 9, like 1:09am or 17:59 sometimes 1 an hour sometimes more.
We have a BT phone that was working g fine before we went onto VOIP. And also we are getting more nuisance calls which aren't being blocked
The 'unknown numbers' problem a 'known issue'. See this topic
When the hub was swapped from 4 to 5, does caller ID still work OK on your line? The BT trueCall screening relies on caller ID working correctly in order to do the screening. Haven't read all of the posts on this theme in detail but BT phones do seem to get quite a few mentions along with the Hub 5.
on 19-10-2022 21:23
hi,
the phone doesn't ring, we get them almost every hour, but the times are In the format 07:19 , 08:19, etc, or 07:29, 08:29, or 07:10, 08:10, so once they start the errors are repated at the same number of minuteslassed the hour, we never had an issue on the hub 4.
we don't have another phone to try, and not buying one to fix a problem, with what appears to be digital noise on the voip port
we are getting anything from 10 to 20 a day
on 19-10-2022 22:19
@Mercman123 wrote:hi,
You would do best to follow along on the main topic about this here
and add your voice to the complaintson there
The last official VM update seems to be here
on 20-10-2022 08:04
Hey @Mercman123, thanks for reaching out to us and welcome back to the Virgin Media forums.
I'm sorry to hear that you as well have been affected by the issue.
This isn't the first so what I will do is refer this case to our team who will investigate the matter.
The number of cases relating to this is growing and growing.
Once we have an update about this we will keep you updated.
Kind regards,
Ilyas.
on 20-10-2022 11:50
this ongoing 'known issue' which we have had since the Hub5 was installed early September should be an easy fix, just need the right clever person who can see what needs updating or changing in the Hub 5 modem settings to stop it calling the landline every hour.
as scrolling through 20 plus missed calls a day to see if there are any genuine missed calls is a bit time consuming and annoying.
fix it please asap. or knock money of our monthly bill until you sort it that might speed you all up into finding a solution faster.
on 20-10-2022 12:11
Hey @Davesobratty, thank you for your query on the Virgin Media forums.
Thank you for bringing this to our attention, as mentioned it has been logged with the relevant team to fix.
Unfortunately it is not an "easy fix" as the team needs to see the issue, what causes the issue, any linking factors and the issues behind it.
Once they have done resolving the matter they will roll out the resolution ASAP, which will be through a software update.
As stated, the case is with the team for them to fix.
Kind regards,
Ilyas.
on 22-10-2022 09:35
Hi.....Just searched for this thread after having another 7 missed calls this morning. Switched to Hub 5 earlier this week and been having this problem ever since.
on 22-10-2022 09:48
Hi Blossom53,
A warm welcome and thanks for posting on our community forums. We do apologise that you too are experiencing issues with our HUB5 and receiving missed calls.
We are aware of this issue, and it has been reported. Our engineers are working on a software update to get this issue resolved as quickly as possible.
We appreciate your patience and apologise for any inconvenience caused.
Kind regards Jodi.
on 22-10-2022 13:29
Same here I'm getting strange missed calls from UNKNOWN NUMBER
But nobody has called me at these times?
Also sometimes when I try making outbound calls I get a strange dialling tone? Has anybody else noticed anything similar 🤔 👀
Kind regards
Dean 👌 👍 🙆♀️
on 22-10-2022 13:32
I don't also get strange calls from UNKOWN NUMBER but sometimes the phone actually rings but nothing happens?
And nobody specifically calls me? It even happens sometimes during the night which Is quite frustrating 🙃 😑
