on 12-08-2022 16:10
This is a strange one, so wondering if anyone else has observed something like this...
With the home phone plugged into the Hub 5, I am seeing frequent missed calls from 'No number' at a variety of times during the day. But if I call 1471 I am getting call data older than this (which relate to 'real' calls), so seems like we are getting spurious missed call data to the phone from the Hub.
Has anyone else observed anything similar?
on 08-09-2022 15:38
Thank you for the update on this @Davesobratty.
Sorry to hear that the issue persisted even after a hub swap. Just to confirm, is it the same frequency of missed calls as prior? Have you also tried a different handset to see if the problem persists?
on 08-09-2022 16:49
same frequency, not tried any different handsets as thats the only ones we have, and had no issue with the handsets with previous hub 3 with same set up.
on 08-09-2022 17:05
Just to confirm, have you checked the handset itself to see if this may be caused by a setting on the device?
on 08-09-2022 19:49
We are still having the same issue, we are using Bt Premium Trio
on 08-09-2022 20:47
@gap84 wrote:This is a strange one, so wondering if anyone else has observed something like this...
Can't give you an answer, unfortunately, but do recall a topic from a few months ago
which sounds like the same issue. Hub model and outcome unknown though but one of the VM team should be able to look up if there was any explanation/resolution back then on that topic.
on 08-09-2022 20:57
Thanks for the response gap84,
To calrify regarding this, are you not receiving calls from a specific recipient or is it happening on most calls?
Let us know,
on 08-09-2022 23:38
Hi Kain
the issue is these ‘missed calls’ from an unknown number that appear to be spurious. So it’s not a particular caller as I don’t think there is one!
As per the post above, looks like there are three examples of this now!
on 09-09-2022 08:13
We have raised this with the relevant team to investigate further, we appreciate you raising this via the forums.
Rob
on 29-09-2022 19:45
Hi All, we had a hub 4 replaced with a hub 5 on Saturday 24th September, and ever since we get random no number calls showing on our habd set today ir was 27, the timings are always at a time with a 9, like 1:09am or 17:59 sometimes 1 an hour sometimes more.
We have a BT phone that was working g fine before we went onto VOIP. And also we are getting more nuisance calls which aren't being blocked
on 29-09-2022 20:01
Hi @Mercman123,
Welcome back to our Community Forums! Thank you for your post and I'm sorry to hear that you're having some issues with receiving strange missed calls!
Have you heard your phone ring out with these calls, or do you just receive a notification stating that a call was missed?
Do you have a different landline phone to plug in to see if this issue persists? Have you recently rebooted your Hub?
Please let us know so we can help.
Thank you.
