on 29-06-2022 16:23
I have no dial tone on my home phone. I have unplugged and replugged. It uses an old style socket with no hub. I am elderly and feel vulnerable without my home phone because I don't use a mobile. The virgin media help pages just show bad gateway when I try to access them. On check status it shows my postcode (West Yorkshire) to be OK and working when I know it isn't. This has happened before, but I forget how it got resolved. I know Virgin admitted it was their problem causing the fault when check status showed it was OK and it wasn't OK. How can I get in touch with an engineer to get this fault sorted, because there is nothing I can do and I'm feeling desperate, not understanding the technology and jargon people use.
on 29-06-2022 17:01
Hello Malcorbett, thanks for joining the community and for making this post.
We are sorry to see about this issue with your landline, at the minute.
We understand how it can be stressful since you do not have a mobile to use as a back-up for calls.
We are eager to help our best from here, this is what our community do 🙂
To enable me to help you out, I will send you a private message shortly.
Please check the top-right corner of our forum and you should see a purple envelope. Click this and you'll see my message.
