  • 8
tdotbeats
Home phone Wont Work
Ever since its been installed a month ago I can't get my home phone to work, the engineer told me that the line connects to the back of the modem, which i did, but after i transfered my number from BT I cant get the home phone to even detect a signal. I keep getting an error saying ''Line error''. service checker seems to say everything is fine but it cant detect a phone connected to the line. I tried diffrent cables and the phone was working up to the day of the switch, I cant seem to get through to virgin support on my mobile.
What can I do?
  • 1.21K
  • 68
  • 97
Re: Home phone Wont Work
Hi tdotbeats,
Thanks for your post.
Sorry to hear that you're still unable to use your landline since the installation. I can appreciate you're keen to understand what is happening.
Are you getting a dial tone at all? When did the number transfer complete? What happens when you call your landline number from another phone?
Let us know and we'll be able to help further.
Melissa
  • 8
tdotbeats
The tranfer was done on the 08/08/19, i get no dial tone from the phone. Calling the number just rings until I reach the Voicemail service.
  • 1.02K
  • 59
  • 193
Hi tdotbeats,
Thank you for getting back to us and confirming these details.
In looking at the backend of your services, it looks like the line has been provisioned correctly from our end and is active. Line tests have also come back successful. Have you tried rebooting your hub since install to see if this helps to connect? If not, I'd recommend giving this a go.
Could you also confirm whether you have an older-style corded phone, or a powered unit which requires connecting to the mains?
Have you tried connecting an alternative handset to see if it's a compatibility issue between your phone and our line?
Rachael
  • 8
tdotbeats
It  finally started working Yesterday nightSmiley LOL,
not sure what happened, nothing changed on my end.
Thank you for your help
  • 1.02K
  • 59
  • 193
Hi tdotbeats,
That's brilliant news! Thank you for letting us know 🙂
It's possible that me running some tests gave it the virtual kick it needed. Either way, I'm glad you're up and running. Do give us a shout if there's anything further we can help with.
Rachael
