on 15-01-2023 08:14
Hi more for a Virgin media representative, i contacted Virgin media on Thursday about a telephone that has dropped low across a street and a road , was told someone would look at it as possible chance a tall vehicle will hit it …
was told I would hear from virgin media regarding the situation an heard nothing, I felt the reported fault was not clearly taken on board by the company an the phone worker ..
Difficult to contact virgin media these days an feel assured with confidence you’re being listened to.
on 15-01-2023 08:23
Hello Pdm123.
Thanks for your first post and welcome to our Community.
It is really great that you have taken the time to report this low cable.
I have a feeling this may not be our as our cables are run underground.
The odd occasions we use a BT Line, Telegraph pole for services. But this would more than likely need to be reported to BT.
Do you have a picture of the cable that needs looking at please?
Gareth_L
on 15-01-2023 08:56
@Pdm123 wrote:Hi more for a Virgin media representative, i contacted Virgin media on Thursday about a telephone that has dropped low across a street and a road , was told someone would look at it as possible chance a tall vehicle will hit it …
Report to Openreach as well
online
https://www.openreach.com/help-and-support/damage-health-and-safety
or by phone
VM has recently started using Openreach poles for installation but more likely to be Openreach kit if via a telephone pole
on 15-01-2023 10:10
on 15-01-2023 10:24
When checking service of the phone line it’s saying a possible fault , an we need to send someone/ an engineer to look at it , as I have reported. Just looking for clarification, I got the how did we do message at once but no feedback
on 15-01-2023 10:32
Hello Pdm123
Thank you very much for that picture,
This would definitely need to go to Openreach as advised by @goslow.
Can you please let us know how you get on.
Do you have a fault with your home phone service.
Gareth_L
on 15-01-2023 10:41
I have never used the home phone line ever in over 10 years, just told I need to keep it .
Just so I’m clear I believe you’re saying the faulty line has no connection with my virgin media services ?
on 15-01-2023 10:44
Hello Pdm123.
With you being with us for over 10 years. I can happily say the services you have with us are connected to you under the ground out of harms way.
Gareth_L
