  • 17
Andy151
Cant ring out and engaged tone ringing in.
Hi I've noticed that my landline can't make out going calls and when ringing in there's an engaged tone. I've plugged in another phone and the result is the same. My friend has called round as he's been ringing us for the last few days and theres been a permanent engaged tone.
Any help please
  • 4.21K
  • 205
  • 936
cybmole
Community elder
Re: Cant ring out and engaged tone ringing in.
either you have a connected or wireless handset somewhere that has been left in an open call state , or there's a fault which will need an engineer.
 so check all handsets, unplug, re-plug to be certain. if fault persists then call it in.
Check first to avoid embarrassment , if its a case of cat sat on phone...
