micky13boo
  • 6
Message 1 of 7
Bleeping Noise
Have a continual bleeping noise on phoine instead of dial tone. Am able to make calls without a problem. How can I stop the bleeping please.
John_GS
  • 15.56K
  • 796
  • 1.46K
Message 2 of 7
Re: Bleeping Noise
Hi micky13boo
Thanks for posting. You haven't got a voicemail have you? Normally that would indicate this.
Best,
John_GS
dannylau
  • 11.54K
  • 963
  • 2.65K
Message 3 of 7
Re: Bleeping Noise
1571 let's you check for messages
micky13boo
  • 6
Message 4 of 7
Re: Bleeping Noise
Thanks dialled 1571.  Have no messages and just gives me a menu to change greeting etc. So still got bleeping.
Travis_M
  • 4.56K
  • 169
  • 335
Message 5 of 7
Re: Bleeping Noise
Hi @micky13boo
Thanks for posting on our community forum
Do you have any other handsets plugged in? Are you experiencing the issue across the other handsets too?
Travis_M
micky13boo
  • 6
Message 6 of 7
Re: Bleeping Noise
Yes and all got the bleeping noise still.  3 months later.
Reece_MH
  • 1.88K
  • 81
  • 173
Message 7 of 7
Re: Bleeping Noise
Hi @micky13boo,
Thanks for your update, and welcome back to our Community Forums.
I'm sorry to hear that this problem is still ongoing. The bleeping normally indicates that there's a Voicemail waiting. If you've checked, and there is no Voicemail present, it can indicate a line issue.
I'm going to drop you a private message to look into this further. Please look out for it in the top-right, in the purple envelope.
Cheers,
Reece - Forum Team
