on 20-04-2024 22:19
What is going on!!!!! My ntlworld inbox is EMPTY!!! There should be 1000 emails in there!!!! Some of those emails are crucial to my decision making process. I HAVE NOT DELETED THESE EMAILS!!!!! I need answers ASAP!!"!
20-04-2024 22:33 - edited 20-04-2024 22:37
Are you looking on a email app, or on webmail?
Using webmail, check all folders including deleted/junk.
Also check if you have any filters set. If the emails are not there, they are likely lost. VM don't keep backups, hopefully you will have at least some. Good luck!
on 20-04-2024 23:31
This is why I use Thunderbird
on 21-04-2024 08:38
This is why I don't use VM email.
on 22-04-2024 08:54
Hi @TonyH123 👋.
Thanks for reaching out to us and welcome to the Community Forums. Apologies for the issues that you are having with your emails. So that we can look into this for you, please can you join me in a private message.
Please look out for the envelope on the top right of your web browser or if you are using a mobile device, it will be located under your profile icon.
Thanks.
Sabrina
on 27-10-2024 23:10
Im having the same problems....my inbox is EMPTY!!! I DIDNT DELETE THEM EITHER!
on 29-10-2024 08:21
Hi Angrybirdme,
Thank you for your post. We're sorry to hear about the emails missing.
I appreciate you have confirmed that you didn't delete them yourself but have you been able to check your deleted inbox to see if they have been moved there?
^Martin
