Chirag27's avatar
Chirag27
Wifi pods flashing white light
Hi, I recently got a new hub installed and also got a new wifi pod (wifi booster) which initially had a white flashing light, but then I got in touch with the engineer and he managed to send the prov...
  • Gareth_L's avatar
    Hello Chirag27.
    Sorry to hear about the pod flashing white again.
    We can take a look at this for you.
    It is possible to get it provisioned from here. save you having to wait for a replacement to be sent out.
    Unless our team have arranged for a replacement already.
    If you can check the logo top right of your screen that would be great.
    Gareth_L
