Hamster1962
2 years agoTuning in
But there are no problems as such.
- legacy12 years agoAlessandro Volta
You have not been gaming when it happens
- Hamster19622 years agoTuning in
No, it happens regularly, every hour on the hour.
- thinkpad2 years agoUp to speed
As has been mentioned, the spikes are VM doing speedtests to check if there are any issues, and possibly so they can brag about their speeds!
I noticed on my Hub 5 they always did this test a couple of times a day. Once at night (3am) and once around 3pm. Although they do sometimes only do 1 test. I'm on the M250 package, so perhaps they do more tests on the fastest package.
If it's not affecting your activities online then I would just ignore it. Personally I would only want my connection to be tested when I report a fault or they notice an issue rather than having it tested every day.
Related Content
- 2 years ago
- 2 years ago
- 6 months ago
- 2 years ago
- 9 months ago
