Finchbee wrote:
I upgraded my Virgin package because I have an O2 volt which gives the next package up. Which means I have now their 1Gb service. This means I have to go from the Hub 3 to the Hub 5.
Previously, on the hub 3 I had it in Modem mode and connected all my unifi devices to the Ethernet port. This worked really well, and I could manage via a CloudKey Gen 2 Plus
I thought it would be a simple switch out but its been far from it. I understand the Ethernet ports dont work in modem mode unless you connect the 2.5Gb link to another router. This is something I dont have and dont want to spend money on.
So the Modem mode is not an option for me
I have now got it set up with the Hub in its standard function but with wireless switched off. Does anyone have an idea if these is feasible as a short to medium term set up. Are there likely to be any issues I will face ?
Would like to figure it out now as I would say to Virgin I need to go back to the Hub 3 and slower connection
This isn't true.
