Leepy1
2 months agoJoining in
Red Light on a hot Hub 3 Router
My hub 3 router has had a solid red light for weeks. We have tried all the reseting options and this doesn’t solve the issue. The speed of the wi-fi at this time is poor and doesn’t support devices ...
- 2 months ago
If the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly. If you wait here a couple of days a VM Mod should pick this up and discuss directly with you.
