priority76
2 months agoJoining in
Red light and no WIFI
I have a red light on my hub. I have tried a factory reset, turning it off and on. It is working plugged in to ethernet but WIFI is not working at all. Please advise.
Please confirm it’s a hub3. Do a pin-hole reset and if the red LED remains it will need replacing.
Yes it is a hub3. Have done pinhole reset and red light persists. Any idea how to get WIFI back working in the meantime?
Hi priority76,
Thanks for posting, and sorry to hear you're having some issues with the hub.
This will need an engineer visit, so I can help I've popped you over a private message.
Alex_Rm
