prehoward's avatar
prehoward
Pod has no power or lights
I have 3 white Wi-Fi pods and one of them seems to have stopped working completely. There is no light when it is first plugged in and I have tried changing to other sockets. My app is no longer seein...
    Sounds like the Pod has failed.  If you wait here a couple of days a VM Mod should pick this up and discuss directly with you.  If your need is urgent, then ring the fault in to VM.
