Is my Hub 3 hot or not ?
It can be the LED is fading or it can be an over temperature fault.
To check login in to the Hub 3 menu at http://192.168.0.1/ use the numeric Hub Password from the bottom side label. ( this is not the Wi-Fi password )
Run the Network diagnostic tool
Scroll down through the results and find the Temperature entry. Is it normal ?
Hi thanks for your response this the result below.
The temperature of your Hub 3.0 is normal.
- Lee_R8 months agoForum Team
Hi Gentlemen thanks for posting.
Sorry to hear you're having a poor connection and the colour of your hub light is causing you concerns. I would like to take a look on your behalf. I am going to send you a private message. Please keep an eye on your inbox in the top right of your screen.
Lee_R
Related Content
- 5 months ago
- 11 months ago
- 9 months ago
