2 months agoVery Insightful Person
see this
________
Firstly... Can we check… are your issues only evident on wifi connections or do you see them at the same times on devices connected on ethernet cables? If you don't know, can you check on one to help diagnose whether it is just a wifi connection issue or it could be network connection/Hub related?
What Hub model is it? What are the various Hub lights showing/doing when this happens if a Hub3 is the base light a steady white(ish) or flashing green?
Related Content
- 3 months ago
- 4 months ago
- 9 months ago
- 4 months ago
- 2 years ago
