Lelli
2 months agoTuning in
Hub red light
Hi, I have a solid red light on my virgin media hub. I've turned it off and back on but once it reloads the solid red light is still there. Any help would be appreciated please.
If this is a Hub 3 and if the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly. If you wait here a couple of days a VM Mod should pick this up and discuss directly with you.
